1988 Other Nissan Models Will not start-however, I can jump
1988 NISSAN
130,000 MILES • 4 CYL • 2WD • MANUAL
RMILLS
I put a rebuilt starter with solenoid and still the same results. Put the key in and all electrica system works except the when I turn the key & nothing happens. I do hear a little click sound when I turn the key. I've also been using the truck by roling and poping the clutch.
Jan 4, 2008 at 4:50 AM
BMRFIXIT
  • 19,053 POSTS
[quote:90cfb29e0a="RMills"]Other Category problem
1988 Other Nissan Models 4 cyl Two Wheel Drive Manual 130000 miles
I put a rebuilt starter with solenoid and still the same results. Put the key in and all electrica system works except the when I turn the key & nothing happens. I do hear a little click sound when I turn the key. I've also been using the truck by roling and poping the clutch.[/quote:90cfb29e0a]
check switch at the clutch padel
check battery make sure its fully charged
check wiring at and around the battery
Jan 4, 2008 at 5:46 AM
