1988 Other Nissan Models hesitation then drives
1988 NISSAN
213,000 MILES • 4 CYL • 2WD • MANUAL
SBW
truck idles good then you start to drive put in gear and then the hesitation until you push in clutch and give it gas what could this be
Apr 19, 2010 at 11:41 PM
  • 110,244 POSTS
Has the check engine light come on? Have you checked for vacuum leaks?
Apr 22, 2010 at 1:28 AM
SBW
no the check engine light is not on
Apr 22, 2010 at 5:36 AM
  • 110,244 POSTS
You may want to start checking for vacuum leaks. Also, do you know how to check for fuel pressure? If so do it. If you don't, let me know and I give you directions.
Apr 22, 2010 at 6:44 AM
SBW
we changed the fuel filter checked all hoses and the fuel pump then we checked the manual transmission fluid and we did not have any in there could this be the problem
Apr 22, 2010 at 11:37 PM
  • 110,244 POSTS
If there was no fluid in it, it may have been binding.
Apr 22, 2010 at 11:58 PM
