1988 Other Nissan Models front drive axle
1988 NISSAN
198,000 MILES • 4 CYL • 2WD • MANUAL
STLAURENT
how do you remove the front drive axles on a 1988 nissan pulsar nx
May 28, 2008 at 3:35 PM
  • 31,937 POSTS
Hi there,
Remove wheels, split pin & large axle lock nut. tie rod end and strut lower mounting bolts (2 off) Pull hub of spline & swing free (wire up out of the way) Using a suitable lever, remove shaft from G/Box it will be a good idea to drain the transmission or use a container to catch oil . Shafts just click back in as there is an internal "C"clip that locks it home.
Mark (mhpautos)
May 28, 2008 at 7:18 PM
