1988 Other Nissan Models crank shaft bolt
1988 NISSAN
168,000 MILES • 6 CYL • FWD • AUTOMATIC
LARRY FAFARD
I have a 98 quest van , timing chain broke, how do I stop engine from turning to loosten pully bolt.is there a tool I can rent? thank you
Feb 29, 2008 at 4:56 PM
  • 31,937 POSTS
Hi there,
Take the starter motor out and use a large pinch bar to lock the ring gear at the block, you will be an assistant to hold it while you undo the bolt.
Mark (mhpautos)
Mar 2, 2008 at 9:31 PM
