1987 Other Nissan Models struts?
1987 NISSAN
125,000 MILES • 4 CYL • FWD • MANUAL
MANDERZ
Just bought an '87 PulsarNX and the camber on the front suspension is terrible. The inside of the tires are worn although the outside tread is about 30-40%.
Will replacing the struts take care of this or is there something more? (bushings?)
Thank you for your answer.
Aug 12, 2008 at 9:44 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
The struts them selfs will not normally affect the camber, (if bent they will) check the lower control arm bushes, and the strut top plate, n alignment & full suspension check will also help locate this problem.
Mark (mhpautos)
Aug 12, 2008 at 10:00 PM
