1985 Other Nissan Models VALVE GAP AND FIRING ORDER
1985 NISSAN
ELIASBADZA
Engine Mechanical problem
1985 Other Nissan Models 4 cyl Automatic
PLIZ GIVE THE VALVE GAP SIZE (INLET AND EXHAUST) FOR sd 25 NISSAN ENGINE
Nov 10, 2009 at 9:10 PM
BMRFIXIT
  • 19,053 POSTS
Need to know what car do you have like is it nissan sentra ,pulsar NX ,pick up
most common is that the valve clearance is .011 INCH or .28mm
VALVE CLEARANCE
NOTE:On all models, start and run engine to normal operating temperature.
Turn engine off, remove valve cover and adjust clearances immediately.
Do not allow engine to cool before or during adjustment, or incorrect valve clearances may be obtained.
Rotate crankshaft to bring No. 1 piston to TDC on compression stroke.
Adjust intake valves on cylinders No. 1 and No. 2 and adjust exhaust valves on cylinders No. 1 and No. 3.
Rotate crankshaft 360° to bring No. 4 piston to TDC on compression stroke.
Adjust intake valves on cylinders No. 3 and No. 4, and adjust exhaust valves on cylinders No. 2 and No. 4.
Nov 10, 2009 at 10:06 PM
