1985 Other Nissan Models sparkplugs or computer
1985 NISSAN
REDNEKWOMAN
Other Category problem
1985 Other Nissan Models 4 cyl Four Wheel Drive Manual na miles
In my 1989 Nissan Hardbody pickup I have no spark to intake side of spark plugs. I also have computer codes 11,12,21. Do I need a new computer? I also have bucking when I go uphill or go over 45 mph uphill
Jan 16, 2008 at 3:03 PM
DURANGOSCORPIAN
Bro,
If you are running 2 plugs per cylinder, you should be running two coils, one for intake and one for exhaust. Have you checked the coil for the intake plugs?
The rotor also has two tracks, one for each plug configuration, the tracks for the intake side may be damaged...replace the rotor...
Also, check plug wires, some may be shorting...
The hesitation on hills could be that your not building revs up high enough to sustain load or may be your vacuum advance isn't advancing(duh? techy huh?)...check timing here too, the load up hill or hard acceleration may "move" the timing if the chain or belt is bad...check timing variation with timing light, the mark should only move moderately if any..
Hint on the computer, personally speaking if your truck still starts your ok there, if this unit is damaged in any way your up a creek without a paddle...
I hope some of this stuff helped you bro...
DurangoScorpion...
Jan 29, 2008 at 6:34 PM
