1985 Nissan 720 with rough idle
1985 NISSAN
MITCHELLCB
My '85 runs beautifully, except for the rough(sometimes dies) idle after the engine gets warmed up. it happens when I press the clutch in and keep it in neutral coasting to a stop while braking! It sometimes dies and I've popped it into gear to fire it back up. I'm trying to find out what it is and how to fix it before it becomes a bigger problem.
Jan 22, 2007 at 8:38 AM
  • 75,988 POSTS
Try looking for TVS/TVV or a vacuum solenoid that might not working properly. also if it has an EGR check for carbon on it
Also won't hurt to check the fuel pressure-might lead to a fuel system problem. Weak Pump when heated
Jan 22, 2007 at 10:12 AM
