1985 Nissan 720 Rough Idle When Warm
1985 NISSAN
MITCHELLCB
My '85 runs beautifully, except for the rough(sometimes dies) idle after the engine gets warmed up. it happens when I press the clutch in and keep it in neutral coasting to a stop while braking! It sometimes dies and I've popped it into gear to fire it back up. I'm trying to find out what it is and how to fix it before it becomes a bigger problem.
Jan 22, 2007 at 8:38 AM
  • 75,988 POSTS
Try looking for TVS/TVV or a vacuum solenoid that might not working properly. also if it has an EGR check for carbon on it
Also won't hurt to check the fuel pressure-might lead to a fuel system problem. Weak Pump when heated
Jan 22, 2007 at 10:12 AM
Suggested Repair
Inspect the TVS/TVV and vacuum solenoid operation, check the EGR valve for carbon buildup if equipped, and test fuel pressure for a pump that weakens when hot.
Conversation Summary
The owner of a 1985 Nissan 720 says it runs well but idles roughly and sometimes stalls after warming up when the clutch is pressed and the truck coasts to a stop in neutral. The expert recommends checking the TVS/TVV or a vacuum solenoid, inspecting the EGR for carbon if equipped, and testing fuel pressure for a weak hot fuel pump.
