1983 Other Nissan Models fuel pump
1983 NISSAN
165,000 MILES • 4 CYL • 2WD • MANUAL
JHATFIELD
We changed out the fuel pump on 1983 datsun 720 and now the fuel pump wont run unless we connect directly to the batery with a wire. Is there a fuel pump cut off switch I may have tripped?
Nov 28, 2009 at 5:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
did you disconnect battery for the repair?
check fuses, fuel pump relay and wiring at the pump.
Jan 8, 2010 at 1:15 PM
