1983 Other Nissan Models alternator belt
1983 NISSAN
TIM
Engine Mechanical problem
just replaced alternator belt but need to tighten it. how do i pry the alternator
Sep 22, 2009 at 10:23 AM
Loosen the pivot bolt on the bottom and adjusting bolt on top and pry the alternator housing away from the engine allow 1/4 in deflection on the middle span of the belt for tension
Sep 22, 2009 at 10:41 AM
TIM
i have loosened both bolts but i am having difficulty moving the alternator. any suggestions for a pry point
Sep 22, 2009 at 11:36 AM
Hit it with WD-40 and set your pry bar between the alty and engine and give it a good push
Sep 22, 2009 at 11:39 AM
