1983 Other Nissan Models 1983 Nissan Pick-up Truck Ignition
1983 NISSAN
CHARNOCKELLIOTT
Noises problem
1983 Other Nissan Models Four Wheel Drive Manual 142000 miles
My 1983 Nissan Pick-up truck has a constant chime-chime ringing sound after I put the key in the ignition. It does not go off until I remove the key. What might this be?
Jul 10, 2009 at 12:49 PM
  • 31,937 POSTS
Hi there,
from memory some of these early cars had these chimes set up so you would not lock the keys in the car, it was a reminder to take the key.
Mark (mhpautos)
Jul 10, 2009 at 10:41 PM
CHARNOCKELLIOTT
So how do I get the thing to stop chimming. It never goes off.
Jul 12, 2009 at 11:17 AM
  • 31,937 POSTS
HI there,
I would say that the relay is stuck, there chimes are buried beep in the dash, the problem that i have is that the data base i have access to via Mitchel 1 dose not go that far back in models i will see if any other mod had information for you, i will post a note in our internal forum,
Mark (mhpautos)
Jul 12, 2009 at 1:19 PM
