1982 Other Nissan Models help
1982 NISSAN
BEGO
Engine Performance problem
1982 Other Nissan Models 6 cyl Two Wheel Drive Automatic
i have a 280 zx turbo its starts and idles fine but when u drive and get to about 20 to 25 miles per hour it chugs and and acts like it will cut out .
replaced fuel filter and fuel pump and added heat to in case of waqter in the take
what else could it be please help
May 11, 2008 at 9:26 AM
MASTERTECHTIM
  • 4,750 POSTS
you are going to have to check fuel pressure and also you can check for exhaust restriction by lowering front pipe and see if it goes ok. also look at coil and wires to make sure we dont have a ignition break down
May 11, 2008 at 10:08 AM
