1999 Nissan Navara 1999 nissan navara
1999 NISSAN NAVARA
KILLA7
Engine Mechanical Problem
1999 Nissan Navara 4 cyl Two Wheel Drive Manual 176430 km's
Good Afternoon,
I have a nissan navara ute and over the past couple of weeks i have had nothing but problems with it . It seems to idle fine but once you start driving and it heats up, it just breaks down and the engine just cuts out . It has been in and out of the mechanics and they still cant figure out what the problem is. At first they said it was the battery so we replaced that and still it didnt fix the problem. Then they thought it was the coil pick up, so they replaced that and the problem was still there. They then thought it was the crank angle sensor module so they replaced that to , i thought it might be the fuel pump cutting in and out but it seems fine. If you could help me that would greatly appreciated.
Nov 27, 2009 at 2:59 PM
Check and monitor the fuel pressure to rule out a weak fuel pump
Nov 27, 2009 at 6:05 PM
