2006 Nissan Murano rear left turn siginal won't work
2006 NISSAN MURANO
127,000 MILES • 6 CYL • AWD • AUTOMATIC
BATHERTON
teh light works when using the remote to unlock door but no break light or turn siginal
how can i fix it?
thanks
Jun 3, 2010 at 6:27 AM
KHLOW2008
  • 41,814 POSTS
Hi batherton,
Thank you for the donation.
Are the lights not working only on one side of vehcle?
For the brake lights, did you check the brake Fuse # 20 ( 10 A ) in underdash fuse block?
Does the hazard lights works?
Jun 3, 2010 at 7:17 AM
EP24
  • 5 POSTS
I am having the same problem on the right side.
The light does work when I first start the car, or hit the key fob, but doesn't work when I break or turn signal is applied. Only the back right.
I will check the fuse and hazards tonight.
Batherton, did you fix yours?
Mar 28, 2012 at 10:56 AM
RIVERMIKERAT
  • 6,110 POSTS
EP24, also check the main ground for the right rear lights. Unfortunately, our online reference isn't letting me see schematics, so I can't tell you exactly where it is, but it'll be behind that side of the seat, near the 'B' pillar base,
Mar 31, 2012 at 4:05 PM
EP24
  • 5 POSTS
Update, hazard flashers do work.
Any other ideas?
Apr 1, 2012 at 11:46 AM
RIVERMIKERAT
  • 6,110 POSTS
Ok, just to verify here EP24:
The right rear brake/turn signal doesn't work when the brake pedal is depressed, or the turn signal switch is activated, after the car has been running for some time frame.
However it does work with the hazards or when locking/unlocking with the remote fob.
Is all this correct?
Apr 1, 2012 at 12:36 PM
EP24
  • 5 POSTS
Yes you are correct.
Also checked all the fuses under driver dash and didn't find any blow .
Apr 1, 2012 at 1:43 PM
RIVERMIKERAT
  • 6,110 POSTS
Ok. When the problem occurs, check for power at the brake pedal switch, on both sides, with the pedal up and with it depressed.
Apr 1, 2012 at 2:08 PM
EP24
  • 5 POSTS
After further investigation, the blinker/brake lights seem to work for 1 flash only, and then after it goes dead. If I shut the car off and then back on the brake/flash/hazards will only work for the 1st flash and then stops working. This only happens on the back right hand side.
Any ideas?
Apr 10, 2012 at 9:15 AM
RIVERMIKERAT
  • 6,110 POSTS
You need to trace the wires and figure out where the power to the bulbs stops.
Apr 10, 2012 at 2:19 PM
EP24
  • 5 POSTS
But the fact that the lights work for even the first few seconds means they are getting power., right?
Apr 10, 2012 at 5:20 PM
RIVERMIKERAT
  • 6,110 POSTS
Yes. Once. You need to trace the wires to the affected bulbs from the bulbs to their point of origin. It isn't going to be fun, but in order to determine what the problem is, it's a necessity.
Apr 10, 2012 at 6:22 PM
