No power and poor gas mileage
100,000 MILES • 1.2L • 2WD • MANUAL
GAVINCLYNE
I have had engine light on and rough car idle for a while now and changed throttle body. It stopped the misfire but would not start now. So I changed crankshaft sensor and now it had a long crank and very little power and high fuel usage.
I have changed the spark plugs, ignition coils, camshaft sensor, o2 sensors and throttle body. Do not know what this could be? My vehicle is a K12 model.
Sep 16, 2018 at 7:00 AM
  • 110,248 POSTS
First, this vehicle is not sold in the US, so my information is very limited. However, what you are describing sounds like a plugged catalytic converter. Take a look through these links. It describes the symptoms, how to check a converter, and in general, how to replace one.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/catalytic-converter-replacement
I hope this helps. Let me know if you have other questions.
Sep 17, 2018 at 10:25 AM
