2007 Nissan Micra Engine locked out
11,000 MILES • 4 CYL • 2WD • AUTOMATIC
KLEM39
battery went flat Door left open
recharged battery
Remote worked doors OK
Every thing else works OK
Engine turns over OK
Engine will not start
Any help appreciated
Feed back on my problem with my Nissan
First off it is a Nissan NOTE, but as I cannot find any reference to a NOTE model I went for the Micro as it seems Very similar.
As it was a private import I thought that I was down for the cost to repair, quoted $120 an hour!!!
However finally go to the person I bought it off and told that it was under Warrantee for 3 years.
He recommended two Auto Electricians, both gave up after a couple hours.
So took it to the Garage that claimed they could fix it.
Seems the engine control?? had to be replaced from Japan at a cost of NZ$1000 Tho they were a bit vague about it all, they admitted total cost over NZ$1600 (Plus I bought a new battery) So Check out and read fine print on any Warrantee before you pay cash
May 8, 2009 at 10:08 AM
DAVE H
  • 13,383 POSTS
check for spark and fuel at spark plugs !
Sep 15, 2009 at 10:12 PM
