2003 Nissan Micra Warning
2003 NISSAN MICRA
BENZON
Computer problem
2003 Nissan Micra 4 cyl Two Wheel Drive Manual 42K miles
I have just bought a nissan micra 2003 model, when I switch on the engine there 3 warnings displayed in the LCD like: ABS warning, Engine Check Warning and Air Bag warning. What is the possible cause for these troubles? TY
Jul 8, 2009 at 6:57 PM
  • 31,937 POSTS
Hi there,
If these lights come on when you first turn on the ignition and go out when the engine is running, that is normal. If they stay on you will have to get a scan done to check for the set fault codes that are causing the lights to stay on, if this is the case, get a scan done and post the codes here.
Mark (mhpautos)
Jul 8, 2009 at 7:01 PM
BENZON
Thanks a million for the answer, i will bring it to garage to have scan bec the warning does not goes out even the engine is running. thanks again and more power to this site....
Jul 8, 2009 at 7:25 PM
