1999 Nissan Micra electrical fault
75,000 MILES • 4 CYL • FWD • MANUAL
TWINCAM1952
I have fitted a new throttle body assembly, distributor, fuel filter, air filter & the engine still misfires badly under acceleration. I recently replaced the ignition leads set and the car drove faultlessly for a mile, until it warmed up, then it once again began to missfire.
The fault code reads 55 No Faults.
Please can you help.
mike
Jun 7, 2010 at 3:48 AM
2CARPRO JACK
  • 11,533 POSTS
Imnot familiar with that model (im in USA) bu tit sounds liek you may have aweak injector.Pull tehplugs adn compare the color of them, if one is lighter than the others it may not be getting as much fuel, which will cause a misfire, but not always set a code.Have you verified spark quality as well? should be bright blueish in color.
Jun 9, 2010 at 2:01 PM
TWINCAM1952
I have checked the plugs & they all have an identical light brown colouring. The plugs sparks are intense blue in colour. The code which was previously 55 for no faults now shows 11 crank angle sensor circuit. I have recently fitted a new distributor & this 1999 micra has the crank angle sensor incorporated in the distributor.
Jun 12, 2010 at 8:16 AM
2CARPRO JACK
  • 11,533 POSTS
That may just do it, when sensors get hot they begin to short out....
Jun 14, 2010 at 1:19 AM
