1998 Nissan Micra battery
80,000 MILES • 4 CYL • 2WD • MANUAL
GARRYC
How long does it take for the battery to power down? In the morning the car will only start when I get a tow for 100yrd the the car starts and its ok all day, starting 1st time, until the next morning then I get the same problem. the car is not firing at all. So how long do I have between rest periods until tjhe batter settles and will not start?
May 19, 2010 at 8:35 PM
  • 31,937 POSTS
Hi there,
this will depend on a number of things, but first i would have the battery fully bench charged and then get the battery load tested, this will show if the battery is any good.
mark (mhpautos)
May 19, 2010 at 8:50 PM
GARRYC
Just checked the battery and it is reading 13v but its only a 12v battery when car is running it increases to 14v. I have not ran the car for 6hrs. Would something be draining it slowly over a longer period?
May 19, 2010 at 11:05 PM
  • 31,937 POSTS
The battery voltage is not the issue at the moment, an internal short will drain the battery as quickly as leaving on a light, you will also have to get a current draw test done on the electrical system, this will locate any draw down on the battery with all systems turned off.
mark (mhpautos)
May 19, 2010 at 11:12 PM
