1994 Nissan Micra Driving up hill
1994 NISSAN MICRA
RK23UK
1994 Nissan Micra Manual 115000 miles
My micra recently has problems going up hill and also feels when I'm driving it that it is going to stall as its missing and not running smoothly as before. I have had the clutch adjusted twice but dosent seem to make a diffrence, i feel it dosent have any power to go up hill. have had an engine service recently. Please can you help. Thanks
Mar 11, 2010 at 12:50 AM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 11, 2010 at 8:56 AM
