1993 Nissan Micra Lack of power
82,000 MILES • 4 CYL • 2WD • MANUAL
PETER APRAHAMIAN
Car lacks power on hills and seems a bit juddery, as if its not getting enough petrol. Engine revs ok when not in gear so suggests electrics/timing is ok?
I think petrol filter may be clogged or fuel injectors clogged. Is this something I can sort out myself and if so, could you tell me how to repair/sort out said problem. Thanks.
Feb 27, 2009 at 10:52 PM
DAVE H
  • 13,383 POSTS
replace the fuel filter and add a good fuel system cleaner to the tank to clean the lines and injector/carb .!
Apr 30, 2009 at 1:38 PM
