1993 Nissan Micra
1993 NISSAN MICRA
110,000 MILES • 4 CYL • 2WD • MANUAL
PUDS
when my micra gets up to temperature it suddenly loses power for a second on and off and starts to kangaroo along,it doesnt do it when its cold
Jul 5, 2010 at 1:41 AM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 6, 2010 at 3:14 AM
