1991 Nissan Micra Timing Problems
214,000 MILES • 4 CYL • 2WD • AUTOMATIC
KUNTAKRU
Air Conditioning
Dear sir:
Cars timing is not responding with compression.
Timing belt was removed and replaced.
When startng it had a clinking sound. I imediately shut it off. Now it only wines without compression at the no:1 cylinder. Do I check valves?
I also reset the timing, but continued to have wining without compression.
Any info will be appreciated!!!
Oct 28, 2009 at 12:38 PM
DAVE H
  • 13,383 POSTS
sounds like you may have bent valves .. do a compression test or remove the head to check ! if you have no compresssion on a cylinder the valves are bent !
Nov 8, 2009 at 9:32 AM
