after fitting a throttle body, will any tuning be required or should the part be correctly calobrated.
Feb 2, 2009 at 8:55 PM
ZACKMAN
✓Experienced Mechanic
Throttle body itself does not need adjustment, the throttle position sensor however needs to be adjusted. Signal voltage (ignition key ON, engine no running) should be between 0.45 - 0.55 volts. Rotate the TP sensor until specified voltage is achieved.
Feb 3, 2009 at 6:45 AM
