2002 Nissan Maxima Cold Start Rattle
ROB S
I have a 2002 Nissan Maxima 6-cylinder with 58,000 miles. When I start the car I hear a rattle that decreases as the car warms. The rattle can still be heard intermittently when driving the car. The oil indicator flickers when I start the car and then goes out. I'm not sure if this would have any impact, but I live in an area that has been below freezing for most of the last month. The car is not garaged. Any thoughts on the cause of the rattle? Thanks in advance.
Feb 13, 2007 at 10:40 AM
  • 75,988 POSTS
Weather Weather Weather Hawk Hawk Hawk
Last oil changed? and Oil vicosity? Are you using a winter grade oil.
The oil gets thicken when cold, therfore it takes time to get all the way on top the engine.During this time the oil pump is working real hard to suck and push oil, as soon as it lightens it takes a break.
And could be a timing chain slapping the guides and excessive bearing clearances.hope this is not the case
HTH Good Luck! Happy Valentines Day
Feb 13, 2007 at 7:50 PM
Suggested Repair
Confirm the last oil change and that the correct winter-grade viscosity is used, since cold thickened oil can delay circulation and oil pressure. If the rattle continues, have the timing chain guides and bearing clearances inspected.
Conversation Summary
The owner of a 2002 Nissan Maxima reports a startup rattle that decreases as the engine warms, occasional noise while driving, and a flickering oil light at startup during prolonged freezing weather. The expert asks about the last oil change and oil viscosity, explaining that cold oil thickens and takes longer to circulate, and also mentions possible timing-chain guide slap or excessive bearing clearance.
