Nissan Transmission
SHADOW1A1
About 2 years ago I got my 1991 Nissan Maxima Transmission rebuilt. Since then, my transmission has worked fine until about 2 weeks ago. I started smelling burned transmission fluid then my car started jerking when I acclerated. After I parked it, and tried to put it into drive, it jus reved up then after five minutes it got into gear but slipped. I took it to my mechanic who did a transmission flush. Initially it solved the problem but after a day it came back. About 2 days ago, my speedometer stopped working but my transmission went back to working fine. Im not sure if I should try to mess with the speedometer if the transmission is back working. Any ideas or help would be much appreciated. Thanks
Nov 6, 2007 at 4:01 AM
ALLANUS MAXIMA
i have a 1992 maxima 3.0 w/190,000 miles. the automatic tramission slips when the o/d is on but works fine when it's turned off.there is a rubber hose on top of the transpan with a u shaped metal tube in it thats just hanging. i don't know if that has any thing to do with it or not
Nov 24, 2007 at 9:09 PM
