Nissan Maxima starts and the dies when cold
MITCHELETZEL
I have a 2001 Nissan Maxima when cold it turns over then starts for a second then dies if I hit the gas it will stay running after about 20 seconds of my foot on the gas I can take it off and it will idle and run perfect. After a drive I can turn it off and on with no problems but if it sets for several hours or overnight it dies when I start it. If I let it set for a few days it takes longer to start.
Apr 5, 2007 at 4:52 AM
  • 75,988 POSTS
[quote:78ed2b6128="mitcheletzel"]I have a 2001 Nissan Maxima when cold it turns over then starts for a second then dies if I hit the gas it will stay running after about 20 seconds of my foot on the gas I can take it off and it will idle and run perfect. After a drive I can turn it off and on with no problems but if it sets for several hours or overnight it dies when I start it. If I let it set for a few days it takes longer to start.[/quote:78ed2b6128]
Start by checking the coolant temperature sensor and cleaning out the idle air control valve air regulator and checking the FICD-fast idle control device.
Apr 7, 2007 at 11:10 PM
CAMERON_BETHANCOURT
sounds like the coolant temp sensor mine was doing the same thing its about 20 bucks
Nov 7, 2007 at 2:53 PM
