Nissan Maxima 2003 - Engine stops immediatley after start
SANDY1722
I have a 2003 Nissan Maxima (SE) - 75k miles.
Somtimes when I start the engine, it suddely stops and all the lights come on. I re-start it w/o any problems.
It was happening once in a while, but off late it is more frequent (2-3 times a week ).
Thanks
sandy1722
Oct 22, 2007 at 11:31 AM
  • 75,988 POSTS
Could be the ignition switch, the ignition circuit that goes to the positive terminal of the coil.
Try this turn key to On and check for power at the coil-do you have it.
Or you can do this take a wire hook it up on the positive terminal of the coil and the other wire end to the battery positive terminal-this will bypass the ignition circuit-also you will see all the lights that normally comes On. Now try to start it.
Oct 22, 2007 at 12:08 PM
