Horrible GAs milleage
KSMOOTH227
I recently purchased a used 2004 nissan maxima se Front wheel drive for 10,000 what a great price "117,000 miles" lol. But anyway i am only getting 14.8 miles per gallon and i should be recieving 20. This thing burns like and Hummer and i dont no diddly about cars. Is this something i have to go to the dealer and get ripped off to fix or does anyone have suggestions on were i should start with fixing this problem. 14.8 miles per gallon wow.
May 12, 2007 at 2:22 AM
SERVICE WRITER
  • 9,123 POSTS
There are many factors with fuel mileage. Simple things like proper air pressure in tires and easy acceleration from stops are important. I would pull a spark plug and check the gap and condition of it.
Thses are extreme examples, but buy a new set of NGK or Auto lite plugs and look at what they are like new for a comparison.
May 12, 2007 at 5:31 AM
KAMO
  • 47 POSTS
Check your air filter for black marks, try replacing your fuel filter and just to double check, I would recommend starting the car and walking to the rear. Listen by the gas tank for a whistle sound. AT that many mile so fast it is possible your fuel pump may be going out.
May 16, 2007 at 8:32 AM
SERVICE WRITER
  • 9,123 POSTS
[quote:b655be298a="KaMo"]Check your air filter for black marks, try replacing your fuel filter and just to double check, I would recommend starting the car and walking to the rear. Listen by the gas tank for a whistle sound. AT that many mile so fast it is possible your fuel pump may be going out.[/quote:b655be298a]
I'n not so sure on the fuel side of it. The engine woould run rough at best from low pressure. The system is designed to work at a high pressure for the injectors to fire properly.
May 16, 2007 at 10:04 AM
