Fuel injectors
JUNGLEMAN906
One fuel injector is bad on my 1993 Maxima.
Where are the fuel injectors located on the maxima
Apr 5, 2006 at 6:49 AM
CHEVY55
  • 9 POSTS
these are the nozzles that inject fuel into the engine-
one for each cylinder. They are mounted on the top
of the engine, on the intake manifold. They are fed by
a common fuel tube, know as a fuel rail. there are electrical connections on the top of each one, wired back to a computor that measures flow and mixture.
Unless you are a skillled mechanic, do not attempt to
mess with this system. Only a reputable garage would
have the right equipment to diagnose and replace any
injectors that are found to be defective.
Jul 7, 2006 at 7:16 AM
