[quote:ed54ab7823="mangasp"][quote:ed54ab7823="rasmataz"][quote:ed54ab7823="mangasp"]I have a manual 2000 Maxima with 122K miles. I recently had the slave "something" replaced on the car for the clutch. Since then the car does not start. The battery is fine and the head lights work and everything seems to work fine. The problem comes when I turn the ignition and nothing happens. usually, turning the key halfway will power on the radio and show the warning lights, but now nothing happens. they guy who replaced the mentioned part swears he did nothing that would make the car like that and saids it's probably electrical. he has no expertise in electrical. Also, this doesn;t happen all the time, but enough to have me worried.[/quote:ed54ab7823]
It would be nice if we know the liter on this engine
How old is the battery/Is the connections tight and corrosion free. also the battery cable at the starter.
How much did you pay him for the slave-maybe he wants more and rigged it to get more. You don't have to be an expert in electrical to figure out a missing fuse or link to replace, who knows that's what he did. If he is a mechanic he has to know the basic fundamentals of electricity in todays technology.
Could be the ignition switch[/quote:ed54ab7823]
The engine is a 3.6Liter and the battery is about 3 years old. The connections to the battery are good. I paid him $220 to relace the slave and the upper and lower hose.[/quote:ed54ab7823]mangasp wrote:
You mean it cranks over but w/n start-if so -remove a plug wire ground to the engine have someone be cranking the engine while you look for spark-Do you have spark?
Aug 19, 2007 at 11:48 AM
