2000 Nissan Maxima Dies on Restart
AMATTHEWS
Car is a 2000 Nissan Maxima GLE with 132,680 miles. The first and major problem is that the car refuses to start for a while after it has been started. The car will start when I turn the key regardless of time of day and temperature but if I start it and then turn it off, after about 2 or 3 starts, it will cut off as soon as the key is turned to start the engine. Turning the key and revving the engine before it cuts off will keep the car on but if I do not do not do this, I have to wait about an hour for the car to stay on by me just turning the key.
The second problem involves the remote key fob. The key fob will lock the doors but will not unlock them, or open the trunk, and the panic button does not work.
Third, the heater does not seem to know what temperature it is like the AC does. Lets say that it is 80 degrees outside, If I set the automatic termostat to 65 degrees it does its job by blowing cold air with the fan all the way up. However if it is 35 degrees outside and I set the termostat to 85 degrees, the fan will be at its lowest setting and will take forever to warm the car. If I manually turn the fan up and then press auto, the fan will return to its lowest setting.
Finally, the dinging sound that the car makes when the key is in the ignition and the driver's side door is open occurs even when the key is not in the ignition. As long as the driver's side door is open the dinging sound occurs.
Looking back I see that I have typed a lot, hopefully this does not deter anyone from reading sharing any knowledge they may have.
Thanks
Andre
Mar 30, 2006 at 1:05 AM
LOSONE
  • 1,616 POSTS
Andre, sad as it seems you have the classic older maxima problems. They are besieged with a plethera of electronic failures.
You engine start problem is a classic low compression problem from engine wear. When hot there isn't enough compression to start the engine. It could be some injector leak by flooding the cylinders further lowing the compression. Classic V6 problems.
The remote entry problem is probably a defective remote. Try changing the battery and see if that helps. Or replace the remote
The Automatic A/C module is defective. They are expensive but you might be able to pick one up at a salvage yard. The other idea is the remote sensors. There are two, one on the dash front and one on windshield side. Make sure they are clean and if the car has been in a smokers enviorment they may be filled with nicotine as they has a slight vacuum applied to sense the air.
The dinging is caused by a defective micro switch in the ignition switch. There is a micro switch that senses the key in and it is probably dirty. Get some WD-40 and squirt it in the key hole a few times while moving the key in and out. This should correct the problem.
Consider jacking up the license plate and running a newer car under it. Somethines one has to balance the cost or repair and attachment to a vehicle. In my years of experience as a garage owner there is nothing older than an old Maxima as I have worked on many.
Hope this helps and good luck.
Mar 30, 2006 at 2:18 AM
AMATTHEWS
Thank you, even though this just put a damper on my day. A newer car? sigh, so there is no way to fix these engine compression problems without paying some astronomical price? Is revving the engine to start it doing further harm? and tell me, what will eventually happen?
Thanks again
Andre
Mar 30, 2006 at 5:07 AM
LOSONE
  • 1,616 POSTS
Perhaps I was a bit blunt is my assesment of your problems but after many years in the business, I don't beat around the bush.
All the harm that has been done, is done. Reving it like you do won't do any more harm. The engine may last years you just have to put up with it. Those engines are assembled like a watch. Overhauling them is almost an impossibility. A good used low mileage engine would do the trick as they lap over several years. Does yours have red valve covers?
What will happen?--One day the car will look at you, let out a long sigh and won't start. Time--not a clue but before the 200K time.
Hope you solve the electrical issues--let me know.
Mar 30, 2006 at 5:36 AM
AMATTHEWS
But the engine is so much fun to drive, this isn't fair... err I mean, oh okay. Yeah it has a red cover.
LOL at your comment about the car letting out a long sigh.
Thanks again
Andre
PS: Oh yeah the remote fob locks and unlocks the doors now, it just won't open the trunk or sound the alarm, both of which I can live without. I think I may have gotten the sensors too, just have to wait for the right temperature. (Wow this is a long PS)
Mar 30, 2006 at 10:31 AM
LOSONE
  • 1,616 POSTS
On an off chance, start the car, let it idle and spray the area around the intake with some wd-40 or carb cleaner. If the RPM rises then the problem could be a cracked intake manifold which could produce the same effects. Worth a try.
Mar 30, 2006 at 11:06 PM
AMATTHEWS
Sorry I took so long to respond, I have been drowning in work as of late. I will give it a try when I get the chance. Thanks again for all the help.
Andre
Apr 11, 2006 at 12:48 AM
Suggested Repair
For the restart stall, suspect low hot compression from engine wear and/or leaking injectors. Also spray WD-40 or carb cleaner around the intake at idle; if RPM rises, a cracked intake manifold is likely. Revving to keep it running should not add harm. A low-mileage used engine is the practical fix if compression is worn, since overhaul is impractical. Replace the key-fob battery or the remote. Clean the dash and windshield climate sensors or replace the automatic A/C module. Spray lubricant into the ignition while cycling the key to free the key-in microswitch that causes the door chime.
Conversation Summary
The owner of a 2000 Nissan Maxima GLE with about 132,680 miles reported four issues: the engine starts when cold or after a long wait but dies on restart after a few short runs unless revved; the key fob locked but would not unlock, open the trunk, or sound the panic alarm; automatic climate control cools correctly but stays on low fan and heats slowly; and the key-in chime sounds with the driver door open even with the key out. The expert attributed the restart problem to typical older Maxima low compression from wear, possibly worsened by injector leak-down, and later suggested testing for a cracked intake manifold. The fob was blamed on a weak battery or bad remote; the owner later said lock and unlock worked. Climate control was blamed on a failed automatic A/C module or dirty cabin sensors. The chime was blamed on a dirty ignition key-in microswitch. The expert said revving would not cause more harm and that a used engine is more practical than an overhaul.
