93 Nissan Maxima - Car makes grinding noise
SKATENYFORLIFE
Hi i have a 93 nissan maxima as stated, when driving there is a grinding noise coming from the front of the car at times. the sound will go away once i ease off the gas. my first thought is its a transmission problem, i checked the fluid and it is very low, im going to flush the fluid and replace it. If i still hear the noise what should i do or check? thanks
Apr 27, 2007 at 8:23 AM
  • 75,988 POSTS
[quote:42c31f4b37="skatenyforlife"]Hi i have a 93 nissan maxima as stated, when driving there is a grinding noise coming from the front of the car at times. the sound will go away once i ease off the gas. my first thought is its a transmission problem, i checked the fluid and it is very low, im going to flush the fluid and replace it. If i still hear the noise what should i do or check? thanks[/quote:42c31f4b37]
You sure its not the front brakes?
Apr 27, 2007 at 9:34 AM
