2008 Nissan Maxima My starter
141,000 MILES • 6 CYL • FWD • AUTOMATIC
JAELLER896
My Starter is acting funny. Some days I will turn it to start and it will start some days it will just click and not start and it ranges from a min of turning on and off to 10mins. I was wondering were the problem could be located
Apr 23, 2009 at 8:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
If you have ruled out your charging system (alternator, battery and all calbes/connections) then it may be a faulty starter solenoid or the starter motor itself may be going out. I suggest having the starter removed and tested. If the starter and connections test OK then the ignition switch will be the next thing to inspect.
Thanks for using 2CarPros.com!
Apr 23, 2009 at 12:53 PM
