2005 Nissan Maxima JERKS
50,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVEN.FAIR
THE car jerks at slow speed rpm rises to high levels.
May 19, 2010 at 10:17 AM
  • 75,988 POSTS
If transmission is not slipping-do below:
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 19, 2010 at 4:15 PM
