2005 Nissan Maxima headlight bulb replacement
MIKLYNE
Engine Cooling problem
2005 Nissan Maxima 6 cyl Front Wheel Drive Automatic
How do you change the left side headlight bulb
Dec 20, 2008 at 12:04 PM
IMPALASS
  • 3,112 POSTS
Hello –
Bulb Replacement
HEADLAMP
1. Disconnect negative battery cable.
2. Turn the plastic cap counterclockwise to unlock it from the combination lamp.
3. Turn the bulb socket counterclockwise to unlock it.
4. Unlock the retaining spring and remove the bulb from the combination lamp.
Installation is in the reverse order of removal.
CAUTION: After installing the bulb, be sure to install the plastic cap securely to ensure watertightness.
Dec 20, 2008 at 4:20 PM
