2005 Nissan Maxima Acceleration
EFRANCO
  • 2005 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 41,400 MILES
I notice that the service engine went on today. My nissan is not accelerating after it reachs 60 miles. It hesitates to pick up. What could the problem be?
Tuesday, July 28th, 2009 AT 10:05 PM
What you need to do here is get the computer scanned for OBD2 code/s and find out what's causing the CEL to come on. Autozone provides this service free.
The following could cause your problem:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Tuesday, July 28th, 2009 AT 10:10 PM
