2005 Nissan Maxima ABS
2005 NISSAN MAXIMA
94,000 MILES • 6 CYL • FWD • AUTOMATIC
D29
Every time I apply my brakes there's a grinding kind of noise and my ABS, slip and VDC light has come on a couple of times. This problem just started all of sudden. Any ideas?
Apr 14, 2009 at 7:11 AM
DYLAN86
If it's the same problem I had get it to a repair shop immediatly. It may be that the abs sensors need cleaned or replaced and it may run you a couple of hundred dollars, but if you wait to long and it burns up your ABS actuator then you are looking at about $3000 to get the problem solved. I am no car expert, so I could be wrong, but this is the same thing that I am going though with my '05 Maxima.
Apr 16, 2009 at 4:54 AM
D29
Thanks for your help. My mechanic is looking at it today so I'm hoping the news won't be too bad. Thanks again.
Apr 16, 2009 at 5:55 AM
