2005 Nissan Maxima
2005 NISSAN MAXIMA
57,200 MILES • 6 CYL • FWD • AUTOMATIC
ADOYLE2009
Ok. I just got this car about a month ago and now the air conditioning is beginning to act up. Sometimes when you turn the a/c on it comes right on and gets really cold but at other times when you turn it on it just blows hot air. Also, when it starts blowing hot air while I'm sitting at a red light, drive through, etc the RPM needle will start jumping from 600-700 to 1000-1500 without me even touching the gas pedal. I called the dealership where I bought the vehicle from and they told me that if I brought it to them and it just happened to be working that they wouldn't be able to fix it. I'm not sure what is going on with the car. My grandfather thinks it may be the compressor trying to go out. If that is the case, how much would this set me back on trying to get fixed? And if I could get it working without having to get a new compressor it would be even better!
Jun 25, 2010 at 2:19 PM
CARADIODOC
  • 34,321 POSTS
Hi adoyle2009. Welcome to the forum. Doesn't sound like a compressor problem. When they fail, they don't magically start working again. The dealer is right that there isn't much they can do when the problem isn't occurring. When the system works, you have to agree every part is working so there is no defect to be found. That is hard for some people to understand. I often ran into the same thing on house calls when fixing peoples' tvs. The exception is when your description of the symptom is a very common one with a known pattern failure. In this case, it sounds exactly like a problem a few Chrysler minivans had in the late 1990s. The cause was an intermittently sticking "H valve". If it stuck closed, no refrigerant entered the car to do its cooling. If it stuck open, too much refrigerant entered and the evaporator in the dash got too cold. The humidity that condenses on the evaporator and is supposed to drip out the bottom of the car freezes instead into a block of ice that blocks air flow. Either problem was intermittent but it was so common, the mechanic didn't even bother to do any testing; he just replaced the valve.
Other manufacturers have their own name for an H valve but the symptoms can be the same. An intermittent electrical issue can also cause your symptoms. The thing to do is to peek under the hood when the no-cooling problem acts up and see if the AC compressor is running. If it is not, that will provide important clues for the mechanic. On most systems the compressor cycles on and off roughly every 5 - 30 seconds so you can see what it looks like. No other belt-driven pulley turns on and off. If yours runs continuously, have a helper turn the AC on and off until you can see which pulley is engaging. You can also have a mechanic point out which pulley is for the compressor so you will know which one to check.
caradiodoc
Jun 25, 2010 at 2:41 PM
