2004 Nissan Maxima Starting Engine
70,000 MILES • 6 CYL • FWD • AUTOMATIC
ADOLF LEWIS
One in ten times when engine is started it cranks for several turns before starting. Other times I restart two time before engine starts.
Oct 12, 2010 at 4:41 AM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel pump and coolant temperature sensor and also the cold start injector if it has one-if all okay could be the ignition switch failing
Oct 12, 2010 at 6:57 AM
