One in ten times when engine is started it cranks for several turns before starting. Other times I restart two time before engine starts.
Oct 12, 2010 at 4:41 AM
✓Experienced Mechanic
Check the fuel pressure to rule out the fuel pump and coolant temperature sensor and also the cold start injector if it has one-if all okay could be the ignition switch failing
