Idle speed
133,254 MILES • 6 CYL • 2WD • AUTOMATIC
RAEFATIE
hello please i have one fault in the engine if i erase by scanner comme back the fault is ISC system can u help me please.
Feb 28, 2008 at 7:51 PM
2CARPRO JACK
  • 11,533 POSTS
That is the Idle Speed Control Motor. Try removing it and cleaning it out with carb cleaner,Also clean out around the butterfly in the throttle bore with carb cleaner and a rag.
Feb 28, 2008 at 11:50 PM
ROB BUSH
I need to adjust the idle speed how is this done?
Nov 9, 2019 at 7:30 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
no adjustment needed on this vehicle, If it is not idling properly than may need to check for component failure such as a vacuum hose leak or the throttle actuator needs service.
FORDPOWERSTROKE21
I had this problem and had service the throttle bore, all fixed I love this site
