ABS Brakes
TKO-IRISH
Brakes problem 6 cyl Front Wheel Drive Automatic 108000 miles
I have a 2004 Nissan Maxima. The ABS braking system is activating when it should not. I also have a wheel that might have a problem - the air is slowly leaking out of a new tire. Could the ABS have a problem because the wheel has an issue?
Jan 7, 2009 at 3:46 AM
YASGER
  • 83 POSTS
This sounds like you have a ABS wheel speed sensor that is not working right. Here is a video to help you run the codes to confirm the issue.
https://youtu.be/rTtAnsOlZU4
Check out the diagrams (Below)
Cheers
Jan 18, 2009 at 3:53 PM
K_S
Feb 4, 2009 at 6:06 AM
K_S
Just heard back. My car needed both rear hubs and ABS Sensors replaced. Just wanted to let you know what fixed it.
Feb 4, 2009 at 6:28 AM
