HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Maxima
Engine
Symptoms
Not Cranking Over
SPONSORED LINKS
Car will not turn over
PREV
1
2
NEXT
MECHANIC
Double check the battery condition and connection-if ok, check the starter relay, transmission range switch and ignition switch.
Thursday, June 11th, 2020 AT 6:44 PM (Merged)
DETOITER
MEMBER
1 POST
1996 NISSAN MAXIMA
6 CYL
AUTOMATIC
200,000 MILES
Starter has a flat spot, what can I do when it won't start.
SPONSORED LINKS
DOCFIXIT
MECHANIC
Cross fingers need to replace will only get to a point it will not start and your stuck with tow bill on top of repair
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
2003 Nissan Maxima Engine Won't Do Anything
Earlier Before I Had My Problem I Was Driving And The Service Engine Soon Light Came On. Now For The Problem, When I Tried To Start My Car...
Asked by
matt194
1 ANSWER
2003
NISSAN MAXIMA
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
2003 Nissan Maxima Car Turns Off While Im Driving
When I Was Driving On Friday My Car Turned Off And Service Engine Soon Light Came On. I Changed Craft Shaft Sensor And Cam Shaft Sensor....
Asked by
carlosc305
2003
NISSAN MAXIMA
All Of A Sudden Engine Locked Up
I Had The Oil Change This Past June Third And The Engine Locks July Ninth Mechanic Claims No Oil. But I Had An Oil Change Five Weeks Prior.
Asked by
Mzricka
2003
NISSAN MAXIMA
2003 Nissan Maxima Engine Burning Oil
My Maxima Has Been Burning Oil At A High Rate Over The Past Several Months (like Almost A Quart Every 500-600 Miles), With The Service...
Asked by
lilithfairfan
1 ANSWER
2003
NISSAN MAXIMA
2003 Nissan Maxima Oil Leak
Oil Leak (spotting When Parked) Persists. Installed New Oil Pan, Old One Was Corroded Through On Bottom Rear Right Corner. Checked Engine...
Asked by
duke44850
1 ANSWER
2003
NISSAN MAXIMA
VIEW MORE
SPONSORED LINKS
Battery Replacement Saturn
Battery Replacement Video
Battery Replacement Dodge
Online car repair manuals
