2002 Nissan Maxima Rear door (driver side) is locked from i
100,000 MILES • 6 CYL • FWD • AUTOMATIC
AMANSOUR14
I have Nissan Maxima 2002 SE
My rear driver side door is locked and I can not open the door from inside and outside ... I can not open it from inside because the child lock is on but I do not know why I can not open it from outside ... Maybe the exterior door handle is bad ...
the center lock is working fine..
I do not know how to remove the inside door panel .. because it is locked
Is there a way to remove the exterior door handle without removing the interior door panel?
please help ... anyone has the same problem before ?
Nov 4, 2009 at 6:27 AM
STEVEW84
  • 673 POSTS
you going to have to take the door panel off to get the rod to open the door. You might end up breaking it a little since you won't have the door open.
Nov 5, 2009 at 11:44 PM
