2002 Nissan Maxima HIGH PITCH NOISE
92,000 MILES • 6 CYL • FWD • AUTOMATIC
ASPER79
I hear a high pitch noise when I am driving and slightly turn my steering wheel to the left... I do not hear the noise when my steering is straight or to the right .... I just had the wheel bearing and housing replaced on that side... I was not sure it might be the break pad. If you could help that would be GREAT!
the noise is really heard at speeds at 40 or 60
Feb 20, 2009 at 1:09 AM
  • 110,248 POSTS
Hi:
Does the noise change when you use the brakes? If so, it is most likely the brake sensor letting you know the pads need replaced.
Feb 24, 2009 at 5:23 AM
