2002 Nissan Maxima ABS Light On
108,000 MILES • 6 CYL • FWD • AUTOMATIC
QUEENPATTY2001
Hi. My ABS light, TCS light and SLIP light came on. Mechanic told me I need a right front speed sensor as its worn out. Cost for parts and labor is $322. Is that a fair price? I'm single and not sure if that's too high for what he says the problem is. Thanks!
Aug 24, 2010 at 12:37 AM
SATURNTECH9
  • 30,869 POSTS
That's on the high side i Have a list price for the sensor as 163.15 plus tax.the labor is only .7hrs less then a hr time's shop labor rate 80-100 per hr?What i would do is shop around and find the part somewhere and bring the part in with you to get it installed.So just to give you a example if the shop labor rate is 100 per hr then labor to install your sensor is only 70.So if you do the math 322 is pretty high what he told you.I would go somewhere else when you get the part.
Aug 24, 2010 at 6:21 AM
