2001 Nissan Maxima VALVE GASKET
2001 NISSAN MAXIMA
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALLENJ
hi guys, my girlfriend was told by the dealer that she needs a valve cover replacement asap or it wouldn't be repairable. they quoted $1,450.00 - this seem very high! there's been no oil on the garage floor or smell of burning oil from the engine compartment. does this seem right?
thanks, al
Apr 16, 2010 at 7:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
just because no oil is leaking doesn't mean the valve cover is good, could still have crack and letting compression escape which could do engine damage. that quote is EXTREMELY high just for removing and replacing your valve cover though. labor costs shouldn't exceed $300 and parts would only be around $50. may want to take to another shop .
Apr 16, 2010 at 1:59 PM
ALLENJ
thanks, that's what i thought but they said they have to drop the trans to replace the gasket.
al
[quote:f731369329="bluelightnin6"]just because no oil is leaking doesn't mean the valve cover is good, could still have crack and letting compression escape which could do engine damage. that quote is EXTREMELY high just for removing and replacing your valve cover though. labor costs shouldn't exceed $300 and parts would only be around $50. may want to take to another shop .[/quote:f731369329]
Apr 17, 2010 at 12:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
to replace the valve cover gaskets??? are you certain they are talking about valve cover gaskets?
Apr 17, 2010 at 2:57 AM
ALLENJ
yeah, valve cover gakest and because the trans must be droped, the main/center gasket must also be changed - shops confirmed this and quoted $1,22-1,400 - but how do we know it is even necessary?
thanks, al
Apr 18, 2010 at 2:46 AM
