2001 Nissan Maxima Starting problems
13,700 MILES • 6 CYL • FWD • AUTOMATIC
BARNEY22
Hey, i need help... for a wile now my car has had a problem starting unless you push in the gas then it starts up just fine and works great until today i tried to start my car after work and forgot to push the gas in during the starting process and it didn't start so i took the key out tried again and all i could hear is one CLICK and nothing would happen i tried several times and all i hear is one CLICK then nothing can you help? And by the way It's a 2001 Nissan Maxima GLE
Aug 15, 2010 at 3:05 PM
  • 75,988 POSTS
No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link,the starter,starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Aug 15, 2010 at 3:20 PM
BARNEY22
Do you think my starter is seized up?
Aug 15, 2010 at 3:37 PM
  • 75,988 POSTS
Try shorting out the starter solenoid and see what happens
Aug 16, 2010 at 2:37 AM
